Page 5 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 61 to 75 of 177
  1. #61
    Sep 2004
    Glastron Molinari
    Your boat was originally purchased new by Dick Sharp\Bryant Corporation out of Seattle WA. It is a 1969\70. I was crewing for my uncle's during that era and saw it run at all the local races that season until it blew over and broke Dick's leg. He continued to run it the next season until teaming up on a new boat for the 1972 season. That boat used an Evinrude as the Bryant Corp was the OMC distributor I believe (I was 15 so I'm dusting the cobb webs off).
  2. #62
    Feb 2003
    Tacoma Wahington
    Thanks 390r
    Thanks for the background 390r. Welcome to Scream & Fly.
    Every little bit of information helps. The Glastron is about to get rolled into the shop for her full body makeover. There’s a lot to do but Joe is set on having it done by spring.
    More pics soon.
  3. #63
    Feb 2003
    Tacoma Wahington
    Glastron
    Here is an update on Joe’s Glastron. After a couple of weeks in the cue the team at Sankuer Composite Technologies (www.sankuercompositetech.com) got to work. (BTW- if you need some world-class composite help in Michigan, gives these guys a shot). It’s really great seeing the original yellow color show itself. Note that we trimmed the cockpit sides back to the original shape. The rear cowl is back to the original too.
    As is the case in a restoration project like this we found the transom wood has spots of rot. The wet wood was encapsulated deep inside. The new transom will be installed this week.
    In addition to making sure the structural integrity was sound one of our objectives is to make sure the boat stands tall cosmetically. To prevent the inevitable cracks from the old resign reappearing it will get a thin glass veneer on the decks. It will not add much weight but will make a nice stable base for the new paint.
    The next challenge we need to address is the dash. Since we are taking this back from the inline six power to the OMC KC we need to plug the existing holes and figure out the period OMC set-up. My recollection is that boats from this era didn’t have “race” instrumentation beyond the trim indicator. I would appreciate it if anyone could confirm this assumption. If it did have a tach, which one would they have been used on an OMC KC?
    390r was kind enough to help us with some information regarding the history of this boat. We are told that it held US 1 title at some point. We have some Sherlock Holmes to accomplish but we’re hoping to bring it back as it was when Dick Sharp owned it.
    Hey 390r………… I really understand the cobweb comment. I too was about 15 at that time.
    We’re having fun with this one. Thanks for all the help guys.
    scot
    Attached Thumbnails Attached Thumbnails sf1DSCN0781.jpg   sf2DSCN0785.jpg   sf3DSCN0792.jpg
    Scot Keller
    45M
  4. #64
    Oct 2006
    Changes with the week
    Looks GREAT, Scot!
    It REALLY is nice to see the yellow finish again. The boat would have had a tach, and a water pressure guage. The also would have been a Keller Speedometer mount block on the dash. That would have been about it.
    The boat will be a showpiece. and would make anybody proud!
    Zonkercraft
    Vintageopcracing@aol.com
  5. #65
    35 Post(s)
    Further Info About This Boat
    Scott -
    I just dug up a 30 year old Northwest Tunnel Boat Racing program. It has a photo inset from the 1969 World Championship Race at Lake Havasu. Your boat (driven by Dick Sharp) is running next to Cesare Scotti in boat #33. Dick Sharp's number was #511 and the number was painted on a black background oval / circle atop the deck black stripes about 20 inches forward from the transom. I don't know if this information might come in handy if you intend to restore it to the OEM condition when Sharp raced it.
  6. #66
    Hot Springs, AR.
    1969 Lake Havasu Race
    I just had 45 minutes of 8MM film made into a DVD of this race. It's shot from the bank, no editing, people walking in front me, '50's hand wind camera. On a 52" sony 1080 HI-DEF it has some good shots-WINGS, MOLINARIS, GLASTRONS, JONES, HALLATT, FELLER, STACKERS BY THE DOZENS, OMC, CHRYSLER, SINGLE,TWINS, TRIPLES. Kitson blowing a lower unit on Saterday.
    Oil smoke so thick on the start you could hardly see and late in the day. If Greg doesn't object, I will sell a copy for $30.00 delivered. Give me a PM.
    Backfire
  7. #67
    Feb 2005
    Ohio
    Quote Originally Posted by Scot Keller View Post
    The next challenge we need to address is the dash...... My recollection is that boats from this era didn’t have “race” instrumentation beyond the trim indicator. I would appreciate it if anyone could confirm this assumption. If it did have a tach, which one would they have been used on an OMC KC?
    Came across some film of a 1969 Molinari doing some testing. Since that is the time period of the Glastron/Molinari you are working on, thought I'd try to get a shot of the dash for you guys. I can't help with what the OMC may have used, but at Merc at that time there was (left to right) a Keller, water pressure, tach and a trim gauge. I'd guess that all that was used on the 1970 models at Racing was a Keller and a trim gauge.
    Here's a shot of the boat and a couple of the dash.....not good shots, but you should be able to get the idea. Good luck on the restoration project, it will be a great vintage rig to play with .
    Attached Thumbnails Attached Thumbnails Butte des Morts 3.jpg   DASH 2.jpg   DASH 3.jpg
  8. #68
    May 2002
    Granite Quarry, NC
    In most cases, we put the harness plate ( included kill switch, fuel pump, ignition, choke/prime, and start switches) on a cross member at the base of the seat cushion between our legs (very easy to hook up the kill switch cap dangling from a lanyard on your life jacket). You would also have a foot throttle..right side and a foot rest ....left side. Later an "up" switch for trim would have been used on the left foot rest.. The steering wheel should be either chrome or spun aluminum spokes. You mounted rocker switches on each spoke for trim. The outside of each switch was "up" and the inside was "down". We had a coiled wire harness (like a spring style telephone phone cord) wrapped around the wheel hub and then wired into the trim system. (Earlier dash mounted trim was a pain in the *ss and dangerous to boot. I mounted the Keller speedo hanger in the middle of the wheel and ran the trim indicator horizontal across the top of the dash in my Glastron Molinari. I think we used Faria tachs at that time, but Merc may have stepped up by then with their own.
    If you can find a break a way steering kit from a later hull, I strongly suggest that you modify the boat to use that. It will cut down on injuries should the worst happen.
    T2x
    20 Foot Switzer Wing 2 X S3000 (Dust'n the Wind II)
    !6 foot Wood Eltro Vee (2X Merc 1500's) (Dust'n the Wind IV)
    15 foot Powercat 15C (2 X Merc 1500) (Dust'n the Wind III)
    (Single engine boats are lacking something)
    15’ Wooden Switzer Shooting Star...
    16 foot Lee Craft Merc S 3000-(Gold Dust II)
    (The exception proves the rule)
    Obsolete and Proud of it
  9. #69
    Clearwater, Florida
    16 Post(s)
    Hi Scot...Here is another Merc dash set-up. The dash set-up on the Mercs and OMCs were essentially the same. In the first picture you can see the blue face of the Keller speedo on the right. In the second picture, directly to the left of the Keller mount, is the tach. The trim indicator is behind the "bent" steering wheel on the left side. The trim rocker switches are mounted on two spokes of the steering wheel. The kill switch is on the lower right hand side of the dash in the second picture.
  10. #70
    Feb 2003
    Tacoma Wahington
    Glastron Dash
    Bob:
    Perfect. This squares with the feedback we have been getting from the others. We have an original blue face Keller but still need to determine what a “period” OMC tack would be.
    Thanks………..
    Scot Keller
    45M
  11. #71
    Feb 2003
    Tacoma Wahington
    Thanks T2x
    T2x:
    Thanks a million for the post. The trim set-up you specify is exactly how we rigged my Dad’s Schultz and Scotti boats in the day. Since the KC was pre-up/down we will not need the toggle on the combing board. The current switch location is between the legs at the front of the seat as you called out. I think we’ll leave it there. I'll also start looking for the tach you mentioned. You make a good point on the break-away steering. We were going to take it back to a fixed hub on the dash but will take a second look at the safety issue.
    Again, thanks a million. Scot
    Scot Keller
    45M
  12. #72
    Feb 2003
    Tacoma Wahington
    More Pics
    As promised here are some new pictures of Joe’s Glastron. The ugly “aero” hump on the back has been removed and the bodywork is progressing nicely. Now that we are down to the yellow color we can clearly see the original stripes. They will be replaced exactly as it was from the factory. Next week the Sankuer Composite guys are going to build a jig to keep the boat square while they replace the rotten transom wood.
    Attached Thumbnails Attached Thumbnails Glastron6a-attachment1.jpg   Glastron7b-attachment1.jpg   Glastron8c-attachment1.jpg
    Scot Keller
    45M
  13. #73
    Aug 2002
    Secord Lake, MI.
    Wow, I wonder if that company could build a race cowl for my Ct15 and convert it back to a center steer race boat like it was originally?
    1977 Python Inline150
    Carlson CT15/90 RUDE(SWEET AND LOW). SOLD!
    Bentley 200Cruise/90hp Evinrude. SOLD!
    Talon18/150Merc: Getting Upgrades. SOLD!
    77 Viking recored SOLD!
    97 Moomba Boomerang SOLD!
    00 Mirage Ski Racer 2.5 200 SOLD!
    1997 Superboat 454/Magnum
    [IMG][/IMG]
  14. #74
    Mar 2004
    Glastron Molinari
    Very Cool project. What was the approximate dry hull weight on one of these boats?
    Jeff
    http://www.powercatboat.com/Group/JBowman/JBowman.html
    A Member in good standing of Dicksmarine, Mesa AZ. "The Land of Misfit Toys"
  15. #75
    Oct 2006
    Quote Originally Posted by Fulltilt View Post
    They could...if you had a plug or a mold
    They do fantastic work!
    Zonkercraft
