Results 1 to 15 of 21
Thread: Wet Sanding
05-15-2002, 11:54 AM #1
Wet Sanding
Decided to try wet sanding first instead of clearcoating. Looking for helpful hints.
Hand sand or use a pneumatic orbital? If hand, straight or circular motion? Use a block or sponge under paper?
I was told to use soap in the water?
Any idea how long this will take?
Going to use 1500 grit.
Thanks guys.
92 STV ProComp
05-15-2002, 12:19 PM #25000 RPM
- May 2001
- Atkins, Iowa
- 330
I did the same thing to a Rapid Craft it was faded really bad! I started with 800 wet, with small spunge and worked up to 2000 grit. Moslty in a straight motion then buffed it out. Lookes like brand new
05-15-2002, 03:37 PM #3
brents on it!!
no circular motion start with a rougher grit and work toward the 1500 put some liqid soap (just a few drops) in the sanding water and go for it, be ready to spend a few good hours sanding and then a few good hours buffing
fastcat thanked for this post
05-15-2002, 03:51 PM #45000 RPM
- Mar 2002
- CT
- 130
Yeah, right on. One more thing to add, yes, do not sand in a circular motion, sand straight, but sand in an "X" pattern. Create cross hatches. When sanding along a radius, do not sand in a straight line along it, sand into it but on a 45° or less angle in one direction and then back over it in the other direction. Also make sure you use plenty of water, I usually just keep a hose just dribbling right next to me to keep wetting it down with.
05-15-2002, 03:53 PM #55000 RPM
- Mar 2002
- CT
- 130
oh yeah, and you probably shouln't use your hand. Get yourself a nice soft block or even a hard block for the big flat areas. You can never apply even pressure with your bare hand.
05-15-2002, 09:08 PM #6
GUYS?
I just bought a high speed buffer and would like to buff my Allison.What kind of compound should i get? Has very very little marks in the paint? 1000 grit?
THANKYOU
Skydog2011 DCB F26
2017 300 XS DBR
05-15-2002, 10:02 PM #7
You guys
I don't get your theroy,In line sanding will staighten and or flaten the area your working.you don't see many people sanding with an air file.Thats why they have a DA,orbital sander,orbital buffer?WAX ON,WAX OFF Daniel-son.
Wetsanding can be done with a DA or waterbug but you better be careful were the gel is thin.If you get a piece of sand between your boat and machine it will F*&@#*&P before ya know it and an 80grit scratch will take about 5 Mil's to clean up.Thats why on any boat that I do I wetsand by hand with a enough water to keep it cleaned out but little enough to let the paper cut.When I got my boat it had a quicky clearcoat job that was peeling so I scraped it off with a razorblade and brought it back,Also did a 23 Eliminator the same way.They will both be at the Glen M-day weekend.Checkem out.
This is just how I was taught by some of the best in my little town and I've only been doing it for 26 years. good luck, Lonnie
05-15-2002, 10:27 PM #8Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,705
- 117
- 85
- 771
did mine by hand with 2000
never occurred to me to do it with a machine. it's not like hand sanding was strenous. i could be wrong skydog but 1000 sounds a little rough. unless the boat is real bad, which from previous posts it doesn't sound like yours is, i would stay on the high side of 1500. try 2000 first in an area, buff it and if you don't like it go to 1500. i think the main thing is to make sure the boat is clean before you start and use plenty of water to keep it that way. good luck, erik kiser
Erik Kiser
05-16-2002, 12:08 AM #95000 RPM
- Aug 2001
- Rotonda West, FL
- 180
WET SANDING
I just did the transom of my other boat ( 34' Cruiser ) to get the shadow left from the previous name when I removed the letters.
I first used 800 then 1200 & then finished with 1500. I then power buffed it with 3M liquid compound. It came out fantastic, looks like a new boat. I used plenty of water & sanded in straight back & forth motion.
'97 Rapid Craft RIOT
MOD 2.5 EFI SS
"BE FAST or BE LAST"
07-05-2015, 12:53 AM #10Junior Member
- Mar 2015
- San Diego CA
- 20
I'm a little more cautious:
make sure it is gel coat!!!
Start with 1500 and use allot of water
working your way to 2200
then the 3m red rubbing compound
for those of you who have production boats & race hulls below 1000# there is a reason, the gel coat is thin just like the rest of the boat!!!!!thats why your manufactures don't do fades and multiple color on the same panel.
when working in areas of blends ( factory fades ) use only 2200 and be very gentle!
either way you have nothing to loose if your willing to put forward the effort.Robsandfreak
07-05-2015, 08:02 AM #11Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
There are some products such as meguires gel restore or the aqua buff product that had a diminishing grit.. Starts off cutting like 1500-1800 grit and the grit buffs down and diminishes to give a near gloss.. Good stuff
Kevin Kiser
07-05-2015, 12:18 PM #12Junior Member
- Mar 2015
- San Diego CA
- 20
Yes Kevin I fully agree. Meguires has a lot of excellent products for restoring gel coat deterioration and keeping toys looking top notch. My personal challenge was finding a source of each of the steps (product) that I needed without buying a case of it. Any Lowes or Home Depot is a source of decent quality wet sanding paper, and the 3m products can be found at a source of fiberglass supplies or online.
Allot of people don't like the Meguires for its silicone content. It makes it shine for a short period and then quickly returns to faded Conditions after a few washes or trips to the lake.Robsandfreak
whipper liked this post
07-05-2015, 05:12 PM #13
I would try starting from 1000 first. As mentioned if its not to bad. You will be suprized how much 1000 takes off. That way you dont risk going down to far and have lots of Gel left for another time 10-15 years from now. Im going to do my BLACK!! windscreen this week some time. Im going 1000 1500 then 2000. Its never been done since new in 2000.
07-06-2015, 07:58 AM #14
I have always wet sanded and gotten good results but 3M has a fiberglass restoration video on you tube that high-lite their products and use an orbital sander and 1200 dry sanding discs. I haven't tried this but it looks worth checking out.
https://www.youtube.com/watch?v=ke5kfYz9Ybw
07-06-2015, 08:48 AM #15
IMO wet sand and clear it. The reason is as mention above that there is probably not a lot of gel to work with. If you just wet sand and buff it will look good but fade back sooner of later and now you with have to remove more gel to repeat process. I would wet sand with 800-1000 grit and use a good clear with UV protector, I like PPG DC4000 for over all, nice to work with but gets good and hard. I know its quite a bit more costly but if you do it this way and you will preserve for ever ok almost forever lol. Just my .02
