Results 421 to 435 of 726
Thread: Merc V6 History
02-09-2017, 04:49 PM #421
They are still locked by the bottom. The rod bearings aren't much of an issue really.
07-26-2017, 09:13 PM #422
So did anybody ever fire old Blue up?
DB
07-26-2017, 10:26 PM #423Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,097
- 1008
- 354
- 4297
- 1951
- 7 Post(s)
they seem to change the rod bearings each heat in the F1 world, saying they cant get the old quality any more?
07-27-2017, 06:42 AM #4245000 RPM
- May 2013
- Pickett, WI
- 210
- 19
- 86
- 362
- 210
07-27-2017, 07:05 AM #425
Best motor I ever owned was a 1980 175hp 2.0L Merc. First year for the big single trim ram. I never had one issue with that motor after three years of racing. I had it on a 17ft Kona V bottom. Not the fastest hull out there but I learned a lot because I didn`t have to worry about break downs so I was able to concentrate on my set up and driving.
DB
07-27-2017, 08:42 AM #426
07-27-2017, 10:01 AM #427
I had a '78 2.0 175....ran it on Nitrous Oxide for 4 years! Never had an issue with h exception of drive shafts and prop shafts!
I did have to run 24v to the starter where it would crank in cold weather....no issues there either!WillySteve Hendricks
20XDC Bullet/Modified Merc 260
295TF Charger/ProMax 225x-Sold!
'83-20' Contender Pickle Fork/Merc 2.4 ModVP BridgePort EFI-Sold!
'85-18' Stratus STV/Merc Hi-Po 2.4 EFI-Sold!
Freedom 240 DLX Fisher Toon/Merc 115
10' Cougar Cub/Merc 25HP On The Bottle!
18" Home Made Tunnel/OS .021XM Outboard on 50% Nitro and Expansion Chamber
07-27-2017, 03:29 PM #4285000 RPM
- Nov 2005
- Lake Eustis fl
- 109
- 33
I was there yesterday, still looks like when I dropped it off
07-28-2017, 02:28 AM #429Screaming And Flying!
- Jun 2012
- England
- 10,973
- 10
- 415
- 2176
- 5 Post(s)
Hells teeth John, Mark and Craig been up to their fetlocks ------at least it's standing up straight !
Its a wonder the COSWORTH'S still under cover-------wonder if I'll get to see either one run again ?
01-03-2018, 03:25 AM #430Screaming And Flying!
- Jun 2007
- 9,097
- 1008
- 354
- 4297
- 1951
- 7 Post(s)
01-04-2018, 10:17 PM #4315000 RPM
- May 2013
- Pickett, WI
- 210
- 19
- 86
- 362
- 210
If the material is the same for both (8620H vacuum-degassed -- bearing quality steel) then the strength should be the same for both assuming the cross-sections are the same. I like the grain structure better in the forging. The hardening should be the same. I'm a mechanical engineer not a metallurgist. So this is not a very professional opinion.
I will say that for a 2-stroke rod, its not the strength of the rod that's so important, it's the quality of the material and the heat treatment of the surface the rollers ride on that really counts. 2-stroke rods almost always start to fail by spalling on this area first.Last edited by rckid74; 01-04-2018 at 10:26 PM.
Kitch thanked for this post
01-05-2018, 02:17 PM #4325000 RPM
- May 2003
- Fond du Lac WI
- 812
- 18
- 84
- 72
- 405
[QUOTE=rckid74;3012015]If the material is the same for both (8620H vacuum-degassed -- bearing quality steel) then the strength should be the same for both assuming the cross-sections are the same. I like the grain structure better in the forging. The hardening should be the same. I'm a mechanical engineer not a metallurgist. So this is not a very professional opinion.
Jerry, and this is just my two cents, but when we were making upwards of 3000 622-4850 rods per day at tmes, plus your 624- rods, there would have been no way carving them from billet - Modern Drop Forge in Blue Island IL was our forging vendor, and very good at it also. I think the prior vendor was out of Rock Falls Illinois and there were times we had to 100% inspect incoming rod forgings due to misstrikes, mismatch, poor fill, straightness, you name it. Modern had thier act together - if there was a price increase it was offset by the quality of the forging. We spent more time fighting our own copper plating mistakes and the silver strike vendor - Electroplating. Ole' Buck Bucarma - he used to carry his supply of silver plate in the trunk of his Cadillac!Last edited by bernie; 01-05-2018 at 02:52 PM.
rckid74 liked this post
01-05-2018, 09:39 PM #433Screaming And Flying!
- Jun 2007
- 9,097
- 1008
- 354
- 4297
- 1951
- 7 Post(s)
Can you forge an H beam rod?
01-05-2018, 09:39 PM #434Screaming And Flying!
- Jun 2007
- 9,097
- 1008
- 354
- 4297
- 1951
- 7 Post(s)
Can you explain the cracked cap procedure
Never seen a vid on that..drill freeze snap?Last edited by powerabout; 01-05-2018 at 10:56 PM.
gfinch liked this post
01-06-2018, 08:45 AM #435
I was told by a Mercury rep some 30 years ago it was just what you said. Machine-Freeze- Snap with a cone, found a video that might be what is done today?
https://www.youtube.com/watch?v=QlVrDJBiqd4James H. W2F a V-King... Want 2 Fly a V-King
rckid74 thanked for this post
