Results 1 to 7 of 7
    Central Il.
    Water walking????
    I have a question about why my boat water walks? I does it at top speed which is about 65-70mph. I have a 295 pro elite stratos boat with a 200 johnson. Just curious if anyone has any ideas. Thanks
    Oct 2003
    Cobourg, ON
    It's called chine walking. Use the search function, there are a lot of threads on the subject.
    Welcome to Scream and Fly!
    Alva, Florida
    Its called chime walking ,need to ckeck for play in steering ,warn motor mounts and more seat time to learn to control it
    20 SHADOW 300+ V8
    Oct 2003
    Cobourg, ON
    A chime is the sound the doorbell makes. A chine is the intersection between the hullside and hull bottom. CHINE not CHIME.
    Merc Lover, what kind of steering do you have?
    Sep 2002
    Solvang, Calif
    Chinese
    Let me Chime in on this Chine walking
    Must be cold up there.
    Gary
    Central Il.
    Thanks guys! i found a video a guy put together to describe it and how to handle or correct the problem. Thanks.
    Prince George B.C. Canada
    Talking water walker
    Just be safe! You will most likely find your top speed will inprove once you can get threw the learning curve. When you can run her straight with no chine walk pinned you can play with the trim.Sometimes one bump up will get you several mph. Just be carfull not to bump her up to far at 70+ . James
