Results 1 to 15 of 22
02-09-2007, 07:25 PM #15000 RPM
- Jan 2005
- levitown
- 696
what is the difference from a 260 crank to a fishing motor crank
whats the difference????????? i have a non oiler crank from a 2.0 (top crank measurement is 1.5 inch,the same measurment as my old 260 crank)) will this hold up to the rpm's if not how many rpm's is this crank good for ?????
02-09-2007, 07:41 PM #2
far as i know there the same. someone with more crank knowledge will chime in soon. mt
02-09-2007, 07:48 PM #3
Depending on who you are buying it from it could be over a grand.
Ló fasz racing
Joe Horvath
02-09-2007, 08:12 PM #45000 RPM
- Jan 2005
- levitown
- 696
Originally Posted by jphii
02-09-2007, 08:32 PM #5
cranks
They are different if you have a 150hp non oil injection crank it is a bottom guided crank and the center mains are different make sure you check that becuase they are several different centers some cranks have a lip on them that support the bareing and some are flat if you use the wrong one it will take out the bareing.if you had a 93 260 it is a top guided crank and your 150 crank is bottom guided so i think the centers are smaller on your 150 crank.hope that helps keys dave
02-09-2007, 10:05 PM #6
You need to talk to Ruck or Brendan Power...
Ruck told me the fishing motor crank will not hold up as well as the 260 hipo crank. Apparently there is additional bead blasting, or something, that occurs between machining processes for the hipo cranks that the other cranks do not get.
He was very adament that they are not the same. I was also thinking of using an oiler crank...but I listen to Ruck.
Scott
02-10-2007, 09:50 AM #7Screaming And Flying!
- Springfield,La.
- 6,579
- 17
- 2 Thread(s)
I won't argue about tha metal in tha differnt cranks, kuz I ain't a metal specialist, but I have put 2.0 fish'in cranks in 260's that have seen rpm'z over 10K, and I now have a F1 2.0 mota with a 2.0(oiler crank) and it will turn 11.5K!!!.....I personally kan't see mercury use'in differnt metals in differnt cranks, but what da hell I no.....Tha metal question would be a good one for Cy!!!!......Oh, and I have top guide rods in tha lil F1 mota, on a crank that had bottom guide rods!!!.....But maybe junkyard mota's live by differnt rules!!!
02-10-2007, 10:03 AM #8
cranks
it will as long as you use the right center mains.
02-10-2007, 11:32 AM #9Originally Posted by T-REX86 Hydrostream Vector
2.4 Bridgeport Offshore Centerhorn EFI
2007 Regal 2860 express cruiser
1996 Rinker 260 Fiesta Vee
Kawasaki 750 ZXI jetski
02-10-2007, 04:50 PM #10Screaming And Flying!
- Springfield,La.
- 6,579
- 17
- 2 Thread(s)
02-12-2007, 11:07 PM #11
I recently found a new way to figure it out...
I am going to do whatever Brendon Power tells me is ok to do. I will run this by him and see what he says.
I am not the experimental type. Can't afford it. After blowing up my last one after 6 hours of breakin time, I am almost scared to crank my engines, much less experiment with possibly using the wrong crank.
Scott
02-13-2007, 08:36 AM #12Screaming And Flying!
- Springfield,La.
- 6,579
- 17
- 2 Thread(s)
02-13-2007, 02:03 PM #135000 RPM
- Jan 2005
- levitown
- 696
i would guess that if you are using a 2.0 crank , order the bearings for the 2.0 crank . or if you take the crank out of a motor and the bearings are good ,just use the bearing that are on the crank already. and there should be no problems, no matter what motor you put the crank into ?????? i would say if you find a crank or buy one from someone then you really need to know the difference , i guess the bottom line is match the crank with the right bearings and you should be good to go no mater what engine it goes into . am i right ????????? if not let me know !!!!!!!! thanks
02-13-2007, 02:05 PM #145000 RPM
- Jan 2005
- levitown
- 696
ruck told me that the hi po cranks are shot peened . i understood that the metal is the same
02-13-2007, 04:52 PM #15Screaming And Flying!
- Springfield,La.
- 6,579
- 17
- 2 Thread(s)
If U use a 2.0 crank in a 2.5, U have to use 2.5 bearings......If U use a 2.5 crank in a 2.0/2.4 U have to use the 2.4 bearings that don't rub the crank shoulder!!!...I don't know the numbers....
Tha only reason U have to use 2.5 bearings wit 2.0/2.4 crank in a 2.5 iz kuz tha 2.5 block haz a bigger external bearing diameter!!...Tha crank journal dia. iz the same!!!(we are reffer'in to tha center 2 mains!!)...Lower bear'in iz tha same on both...tha top bear'in iz tha same outside dia, but thers 2 differnt size inside diam...in both older and newer mota'z!!
