Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
    Dec 2006
    Schuster Tahiti / Sanger boat
    Hello all! I posted awhile back asking if I dhould buy a boat - no idea of maker and a lot more about it - -well I did it!
    I am currently working with the Colorado State Parks system to see if they can do a reverse look up of the hull # to determine the manufacturer, etc on the boat.
    I have seen some pictures that make we think it is a Schuster Tahiti. Does anyone out there have one of these? Does anyone know where I might find infromation on them? I can't seem to find anything on the net - -maybe I don't know what to look for?
    I also have people thinking it might be a sanger - did snage make boats in the early 70's? Based on the pump in this one, that's about how old Berkeley thinks it is.
    If anyone has any information, please pass it on
    Thanks again!
    Aug 2005
    liberty in
    sanger was making boats in the 60's. post some pics
    damn the bad luck
    liberty indiana
    Quote Originally Posted by cographix
    Thanks again!
    If you have a hull number, use this site to find the manufacturer. http://www.uscgboating.org/recalls/mic_database.htm
    Once you are sure of the make, you can find info.
    Dec 2006
    I guess I should have said the hull has a number on it given by the state of Colorado. I don't seem to find the tru hull number (the 12 didgit one) on the stern - -anyone have thoughts for where else it might be?
    Aug 2005
    liberty in
    some of the 60s boats did not have anumber on the stern look for one on a tag under the dash
    damn the bad luck
    liberty indiana
    Northern ILL.
    On hot boat the is a member named oldrigger, he worked for Tahiti for number of years, and knows everything about them
    UMPBA 926 Gas Jet
    Oct 2006
    Chandler Arizona
    HIN'S started in 72. I just looked up my HIN, boy are they wrong. It said I started the Biz in 1976. Not so it was 1988. But old address is spot on.
    I had a 72 Sidewinder that had the numbers stamped in the aluminum rub rail. They were on the right side in the rear.
    Jan 2007
    Winfield, British Columbia
    Quote Originally Posted by OldSleekOlds
    Hey O.S.O., Was the serial number on the actual rub rail, or was it on the metal piece that capped the transom ? I'm missing that piece on mine, and there is no other stampings indicative of a s/n. Unfortunately, there was no 'tag' under the forward deck either.
    Dec 2006
    Yee haw state of Colorado. Apparently what I have is a 1968 Biesemeyer jet boat.
    Anyone have and ideas on these boat, or experience with them?
    Thanks everyone for your help!
    Quote Originally Posted by sspeed66
    It was a metal piece that covered the cap seam. Also served as a rub rail. Aluminum, about 1/2" wide. I had it off when I re-gelled the entire boat. I noticed the numbers when I was putting it back on.
  12. #12
    Oct 2006
    Chandler Arizona
    Biesemeyer boats were built here in Arizona years ago. The even had a few tunnel hulls. They were the flat bottom mold with incerts clayed into the mold to form the tunnel. Rusty was the old guy that built them. And the one of the sons or something like that is building a "T Square" saw fence thing. They made one hell of a drag boat, and river racer with a V drive.
  13. #13
    fairfield ca
    schuster tahiti
ID:	245119Click image for larger version.
ID:	245120Click image for larger version.
ID:	245121 a picture of my schuster tahiti
  14. #14
    Sep 2010
    Central Illinois
    nice..looks lil tight w/ 3 people! is that a 16' or 14'
    I ain't here for a long time, I'm here for a good time !....................
  15. #15
    Mar 2010
    Brigham City, Utah
    Quote Originally Posted by cyataz View Post
    Cyataz,
    Awesome looking boat bit I think it is a Tahiti Brand name and not a Schuster Boat.
    Tahiti Boats made a whole line of SK/SJ boats back in the late 60 throughout the 70s that would make a Schuster Boat look like a bath tub toy as far as performance.
    As I understand Schuster bought a bunch of Over Stock Tahiti Emblems with the Tiki Head trademark Logo and used them on his boats.
    The deck on a Lo Pro or Ski Boat was slightly different with the ridge running down the center of the bow.
    Unless a lot of work and Stringers were added to a 16" Schuster one would have a heck of a time dropping that beast of a motor in one.
    Sidewider did make an 18' Jet with a V8 but as I recall the 16 jets were a in line 4.
    This is my 1971 Schuster Tahiti Torino when I bought it.
    Now with new interior.
