Results 1 to 11 of 11
Thread: Hydrostream HST Prop
12-28-2006, 03:14 PM #1
Hello fellow go fast friends,
I have an 89 HST with a 2.5 merc on the back. My cousin met a guy who claims to know pipcorn and the other fellow who built these boats. He also owned one some time ago. He suggested to take my 3 blade 30p chopper off of the boat and swap it for a 4 blade 28p Spinelli. He said it helps lift the boat much quicker than the other. Has anyone had experience with this? <O</O
12-28-2006, 03:32 PM #2
check with Russell [Russ] His HST runns 110 plus!
why ask me ?
12-28-2006, 07:08 PM #3
my buddy has an hst with a 2.5 280 turns a 30 lightning @ approx. 110 and has not hit the rev limiter, boat works real well.
12-29-2006, 08:16 AM #4
Is that a 3 or 4 blade?
12-29-2006, 09:14 AM #5
I ran a 29 srx at 7200 at a touch under 100. Boat had more but set up was wrong.
12-29-2006, 09:21 AM #6
Hey Boz,
I finally got the floor replaced in the HST. I will post some pics some time. I had to remove about 90% of all the wood. What a job that was.
12-29-2006, 12:41 PM #7
Mike Balz (balzy) would also be a great person to get in contact with. He runs a 2.5 on his and it looks like he's aced his setup. It also looks like he's wild about the HST...can't blame him !
(Apricot)
Hydrostream Ventura II/Merc (sold)
(Bruiser Scheme)
Hydrostream Viking/Merc (sold)
(tri color letdown scheme)
Hydrostream Valero/Merc
12-30-2006, 08:07 AM #8
I ran a 3 blade on my HST for a long time, my particular boat has a harmonic which is crackin things, gearcase housings and props, after the 3rd prop I switched to a 26p mazco re4 and have not regretted it...it runs so much smoother, and for a overall ride prop is excellent.However, for drag racing a 24p yamaha or lightning et is still the ticket....
Wile E. Coyote: (acceleratus vulgaris)
Its amazing how heavy a GPS can be.....
12-31-2006, 12:09 AM #9Supporting Vendor
- Nov 2006
- bradenton ,fla
- 412
prop
Originally Posted by arayliusLast edited by leading edge propeller; 12-31-2006 at 12:13 AM.
01-02-2007, 09:40 AM #105000 RPM
- Sep 2001
- ct.
- 173
never saw an et that was'nt 3 to 5 slower
Weve tried et's and they have nevered carried enought. We have tierd them on hydrostream's,allision's.
I own mazco 28 re3,26,28,30 re4's 27,30,31dr4 spenellis 24alabama cut chopper and a couple of clevers and by far the best it a 30 dr4 I had made for the boat is the best.
It keeps up with the boys running smaller props and runs over 110 any time you want. It's also the best driving.
The 28 re3 ran 108 with my 260 on it with 15" set back.
1350lb hull 300x 12"setback 1.5 to 2 above the pad (the boat needs a hyd. plate because at that height it will hook to the rt at low speed)
If I can be of any help give me a call russ 860-345-8721
01-13-2007, 06:03 PM #11
HST Prop
I have a 1990 HST w/a 280, 14" setback, 1.5"-2" above the pad. So far she has run 104 w/a 14" 30 spinelli 3blade and 102 w/a 15" ron hill 5blade et. The 5blade ron hill has been a great all around. In the spring I will be fine tuning the setup on this boat looking for a little more speed. Hope this info helps...
