Results 1 to 15 of 29
    Aug 2006
    Best intake for old's 455?
    Hello everyone. I'd like to get some opinion's on the best intake for a mild built 455, jet boat engine of course. Any feedback would be great!! Thanx!!
    Mar 2002
    Skow-vegas,Maine
    Many times we have run the Eldebrock with good results on the 455. The most recent 455 we built was for a 4spd car and the customer supplied the intake it was an old Offenhauser Port-O-Sonic and it worked damn good. Pulled like a frieght train and there seemed to be no end to the gear expect for the tach yelling at me to shift. I dont know if they even make this intake anymore but if they do I would definatly consider it.
    OneBigAssMistakeAmerica
    "No good deed goes unpunished"
    81 Sanger Alleycat
    1984 21' Carrazza w/mariner magnum 2.5 200 EFI
    www.rinaldi-engines.com
    Aug 2006
    Did it clear a hei distributer. I heard they have clearence problems with the hei. Thanx for the replie.
    Mar 2002
    Skow-vegas,Maine
    Actually I'm not sure about that as he also suppllied an Accell Distributor too. The accell might have been a little taller but I dont remember it being much different looking then the regular HEI.
    81 Sanger Alleycat
    Oct 2003
    HICKORY, NC
    This greatly depends on the rpm range you need.
    I guess we want a lot of torque for the olds?
    In regards to boat engine.
    Al
    “The bitterness of poor quality & service remains long after the sweetness of low price is forgotten”
    Oct 2003
    HICKORY, NC
    Edlebrock #2730
    This is a great intake from 2500-6500rpm.
    Good intake for a boat, cruising in the 3k range.
    Good thing about this intake is availabilty, and it will clear for HEI.
    And is a non-EGR intake
    Oct 2003
    HICKORY, NC
    Mondello, has the most selection, but what a jerk!
    <TABLE height=129 cellSpacing=0 cellPadding=2 width=745 border=1><TBODY><TR><TD width=316 height=98>
    </TD><TD vAlign=top width=415 height=98>
    Dual Carb/Air Filter w/throttle linkage!
    Offenhauser is the only manufacturer of Dual Quad intake manifolds for Oldsmobiles. Accepts two four barrel carburetors. Ideal for street rods and an impressive engine compartment, especially when they are highly polished. The low profile manifold allows this setup to fit under your stock hood. Dual air filters allow easy access to your individual carburetors. Call us today to order yours!
    </TD></TR></TBODY></TABLE>Intake Manifolds
    <TABLE cellSpacing=0 cellPadding=0 width=744 border=0><TBODY><TR><TD width=742>Porting options are available on most manifolds.</TD></TR></TBODY></TABLE><TABLE height=931 cellSpacing=0 width=746 border=1><TBODY><TR><TD vAlign=center align=middle width=91 height=129></TD><TD vAlign=top width=479 height=129>4150 Mondello Posiflow
    This all aluminum intake manifold for the 400-425-455 Olds engines has an open plenum large runner and is designed for high performance needs. Carburetor base fits a square bore Holley 850 cfm carb. Effective power range from 3000 to 6500 RPM. Can be used with stock or HEI distributors (some minor modification may be required). </TD><TD vAlign=top align=middle width=162 height=129>
    <!--webbot bot="jacpur" startspan CLIENTSIDE PREVIEW="<img border=0 src=""&quot;C:\WINNT\jacpurchase.gif&quot;>" --><FORM action=http://www.justaddcommerce.net/o/order.dll method=post><INPUT type=hidden name=merchantname> <INPUT type=hidden value=0001-4187-0322-5631 name=merchant><INPUT type=image src="http://www.mondellotwister.com/buybutton.gif" value="Add to Shopping Cart" name=additem><INPUT type=hidden value=4150 name=sku><INPUT type=hidden value=$399 name=price><INPUT type=hidden value="Posiflow Manifold" name=description><INPUT type=hidden value=25 name=weight><INPUT type=hidden value=no name=ship_free><INPUT type=hidden value=no name=jac_minimumquantity><INPUT type=hidden value=yes name=taxable><INPUT type=hidden value=no name=jac_no_shopping_cart><INPUT type=hidden value=yes name=jac_disallowfractionalquantity> <TABLE name="OptionTable"><TBODY><TR><TD><INPUT type=radio value=0;Standard;1 name=jac_prodoptions0 rname="manifold">Standard </TD><TD>$399.00</TD></TR><TR><TD><INPUT type=radio value=+200;Stuffer;2 name=jac_prodoptions0 rname="manifold">Stuffer </TD><TD>$599.00</TD></TR><TR><TD><INPUT type=radio value=+200;Ported;3 name=jac_prodoptions0 rname="manifold">Ported </TD><TD>$599.00</TD></TR><TR><TD><INPUT type=radio value="+400;Ported w/Stuffer;4" name=jac_prodoptions0 rname="manifold">Ported <TD>$799.00</TD></TR><TR><TD> w/Stuffer</TD></TD></TR></TBODY></TABLE></FORM><!--webbot bot="jacpur" i-CheckSum="51495" endspan -->
    </TD></TR><TR><TD vAlign=center align=middle width=91 height=92></TD><TD vAlign=top width=479 height=92>4500 Mondello Posiflow This all aluminum intake manifold for the 400-425-455 has an open plenum large runner and is recommended for competition use only. The improvements to this manifold include the use of 4 paravanes at the bottom of the plenum to direct the gas/air mixture through the runners in an even distribution pattern with a minimum turbulence factor. Can be used with stock or HEI distributors (some minor modification may be required). </TD><TD vAlign=top align=middle width=162 height=92>
    <!--webbot bot="jacpur" startspan CLIENTSIDE PREVIEW="<img border=0 src=""&quot;C:\WINNT\jacpurchase.gif&quot;>" --><FORM action=http://www.justaddcommerce.net/o/order.dll method=post><INPUT type=hidden name=merchantname> <INPUT type=hidden value=0001-4187-0322-5631 name=merchant><INPUT type=image src="http://www.mondellotwister.com/buybutton.gif" value="Add to Shopping Cart" name=additem><INPUT type=hidden value=4500 name=sku><INPUT type=hidden value=$399 name=price><INPUT type=hidden value="Posiflow Manifold" name=description><INPUT type=hidden value=25 name=weight><INPUT type=hidden value=no name=ship_free><INPUT type=hidden value=no name=jac_minimumquantity><INPUT type=hidden value=yes name=taxable><INPUT type=hidden value=no name=jac_no_shopping_cart><INPUT type=hidden value=yes name=jac_disallowfractionalquantity> <TABLE name="OptionTable"><TBODY><TR><TR><TD><INPUT type=radio value=0;Standard;1 name=jac_prodoptions0 rname="manifold">Standard </TD><TD>$399.00</TD></TR><TR><TD><INPUT type=radio value=+200;Stuffer;2 name=jac_prodoptions0 rname="manifold">Stuffer </TD><TD>$599.00</TD></TR><TR><TD><INPUT type=radio value=+200;Ported;3 name=jac_prodoptions0 rname="manifold">Ported </TD><TD>$599.00</TD></TR><TR><TD><INPUT type=radio value="+400;Ported w/Stuffer;4" name=jac_prodoptions0 rname="manifold">Ported <TD>$799.00</TD></TR><TR><TD> w/Stuffer</TD></TD></TR></TBODY></TABLE></FORM><!--webbot bot="jacpur" i-CheckSum="40463" endspan -->
    </TD></TR><TR><TD vAlign=center align=middle width=91 height=156></TD><TD vAlign=top width=479 height=156>2151 Edelbrock Performer
    Dual plane aluminum intake manifold for 400-425-455 Oldsmobile street and high performance applications operating in the idle-5500 rpm range. Our VT-581 Aluminum Valley Tray and IG-505 Intake Gaskets are recommended for this manifold. For marine and off-road applications, use HR-350 Heat Riser Block Off Plugs or HR-351 S/S Heat Riser Block Off Plates. Will work with HEI distributors. Will not fit Toronado or 4-4-2 Ram-Air scoop without hood modifications. Center divider can be cut for an additional charge. Use #2732 Carb Plate for square flange Holley Carburetors. </TD><TD vAlign=top align=middle width=162 height=156>
    <!--webbot bot="jacpur" startspan CLIENTSIDE PREVIEW="<img border=0 src=""&quot;C:\WINNT\jacpurchase.gif&quot;>" --><FORM action=http://www.justaddcommerce.net/o/order.dll method=post><INPUT type=hidden name=merchantname> <INPUT type=hidden value=0001-4187-0322-5631 name=merchant><INPUT type=image src="http://www.mondellotwister.com/buybutton.gif" value="Add to Shopping Cart" name=additem><INPUT type=hidden value=2151 name=sku><INPUT type=hidden value=$259 name=price><INPUT type=hidden value="Edelbrock Performer" name=description><INPUT type=hidden value=25 name=weight><INPUT type=hidden value=no name=ship_free><INPUT type=hidden value=no name=jac_minimumquantity><INPUT type=hidden value=yes name=taxable><INPUT type=hidden value=no name=jac_no_shopping_cart><INPUT type=hidden value=yes name=jac_disallowfractionalquantity> <TABLE name="OptionTable"><TBODY><TR><TR><TD><INPUT type=radio value=0;Standard;1 name=jac_prodoptions0 rname="manifold">Standard </TD><TD>$259.00</TD></TR><TR><TD><INPUT type=radio value="+50;Cut Divider2" name=jac_prodoptions0 rname="manifold">Cut Divider</TD><TD>$309.00</TD></TR><TR><TD><INPUT type=radio value=+200;Ported;3 name=jac_prodoptions0 rname="manifold">Ported </TD><TD>$459.00</TD></TR><TR><TD><INPUT type=radio value="+240;Ported/Cut Divider;4" name=jac_prodoptions0 rname="manifold">Ported/ <TD>$499.00</TD></TR><TR><TD> Cut Divider</TD></TD></TR></TBODY></TABLE></FORM><!--webbot bot="jacpur" i-CheckSum="30445" endspan -->
    </TD></TR><TR><TD vAlign=center align=middle width=91 height=155></TD><TD vAlign=top width=479 height=155>2730 Edelbrock Torker Open plenum aluminum intake manifold for 400-425-455 Oldsmobile high performance, drag racing and competition applications operating in the 2500-6500 rpm range. 2732 Adaptor Plate is required for square bore Holley. Our VT-581 Aluminum Valley Tray and IG-505 Intake Gaskets are recommended for this manifold. Will work with HEI distributors. Will not fit Toronado or 4-4-2 Ram-Air scoop without hood modifications. Cone installation and porting options are available. </TD><TD vAlign=top align=middle width=162 height=156>
    <!--webbot bot="jacpur" startspan CLIENTSIDE PREVIEW="<img border=0 src=""&quot;C:\WINNT\jacpurchase.gif&quot;>" --><FORM action=http://www.justaddcommerce.net/o/order.dll method=post><INPUT type=hidden name=merchantname> <INPUT type=hidden value=0001-4187-0322-5631 name=merchant><INPUT type=image src="http://www.mondellotwister.com/buybutton.gif" value="Add to Shopping Cart" name=additem><INPUT type=hidden value=2730 name=sku><INPUT type=hidden value=$259 name=price><INPUT type=hidden value="Edelbrock Torker" name=description><INPUT type=hidden value=25 name=weight><INPUT type=hidden value=no name=ship_free><INPUT type=hidden value=no name=jac_minimumquantity><INPUT type=hidden value=yes name=taxable><INPUT type=hidden value=no name=jac_no_shopping_cart><INPUT type=hidden value=yes name=jac_disallowfractionalquantity> <TABLE name="OptionTable"><TBODY><TR><TR><TD><INPUT type=radio value=0;Standard;1 name=jac_prodoptions0 rname="manifold">Standard </TD><TD>$259.00</TD></TR><TR><TD><INPUT type=radio value=+200;Stuffer;2 name=jac_prodoptions0 rname="manifold">Stuffer </TD><TD>$459.00</TD></TR><TR><TD><INPUT type=radio value=+200;Ported;3 name=jac_prodoptions0 rname="manifold">Ported </TD><TD>$459.00</TD></TR><TR><TD><INPUT type=radio value="+400;Ported w/Stuffer;4" name=jac_prodoptions0 rname="manifold">Ported <TD>$659.00</TD></TR><TR><TD> w/Stuffer</TD></TD></TR></TBODY></TABLE></FORM><!--webbot bot="jacpur" i-CheckSum="27325" endspan -->
    </TD></TR><TR><TD vAlign=center align=middle width=91 height=1></TD><TD vAlign=top width=479 height=1>2810 Edelbrock Olds Victor Manifold
    Designed for the ultimate Pro-Street/Drag Race/Marine applications. This new Victor Manifold bolts right on the Edelbrock Performer RPM aluminum cylinder heads or stock cast iron heads for the 400-455 Oldsmobile engines. Uses a standard flange for an 850 cfm carburetor. We can modify this manifold to fit under stock hoods. (Will not fit without modification.) </TD><TD vAlign=top align=middle width=162 height=1>
    <!--webbot bot="jacpur" startspan CLIENTSIDE PREVIEW="<img border=0 src=""&quot;C:\WINNT\jacpurchase.gif&quot;>" --><FORM action=http://www.justaddcommerce.net/o/order.dll method=post><INPUT type=hidden name=merchantname> <INPUT type=hidden value=0001-4187-0322-5631 name=merchant><INPUT type=image src="http://www.mondellotwister.com/buybutton.gif" value="Add to Shopping Cart" name=additem><INPUT type=hidden value=2810 name=sku><INPUT type=hidden value=$399 name=price><INPUT type=hidden value="Edelbrock Olds Victor Manifold" name=description><INPUT type=hidden value=25 name=weight><INPUT type=hidden value=no name=ship_free><INPUT type=hidden value=no name=jac_minimumquantity><INPUT type=hidden value=yes name=taxable><INPUT type=hidden value=no name=jac_no_shopping_cart><INPUT type=hidden value=yes name=jac_disallowfractionalquantity> <TABLE name="OptionTable"><TBODY><TR><TR><TD><INPUT type=radio value=0;Standard;1 name=jac_prodoptions0 rname="manifold">Standard </TD><TD>$399.00</TD></TR><TR><TD><INPUT type=radio value=+300;Ported;2 name=jac_prodoptions0 rname="manifold">Ported </TD><TD>$699.00</TD></TR><TR><TD><INPUT type=radio value="+149;Hood Mach;3" name=jac_prodoptions0 rname="manifold">Hood Mach </TD><TD>$548.00</TD></TR><TR><TD><INPUT type=radio value=+449;Ported/Mach;4 name=jac_prodoptions0 rname="manifold">Ported/ <TD>$828.00</TD></TR><TR><TD> Hood Mach</TD></TD></TR></TBODY></TABLE></FORM><!--webbot bot="jacpur" i-CheckSum="36625" endspan -->
    </TD></TR><TR><TD vAlign=center align=middle width=91 height=63></TD><TD vAlign=top width=479 height=63>2811 Edelbrock Olds Victor Manifold
    Designed for the ultimate Pro-Street/Drag Race/Marine applications. This new Victor Manifold bolts right on the Edelbrock Performer RPM aluminum cylinder heads or stock cast iron heads for the 400-455 Oldsmobile engines. Uses an enlarged flange for a 4500 series carburetor. We can modify this manifold to fit under stock hoods. (Will not fit without modification.) </TD><TD vAlign=top align=middle width=162 height=64>
    <!--webbot bot="jacpur" startspan CLIENTSIDE PREVIEW="<img border=0 src=""&quot;C:\WINNT\jacpurchase.gif&quot;>" --><FORM action=http://www.justaddcommerce.net/o/order.dll method=post><INPUT type=hidden name=merchantname> <INPUT type=hidden value=0001-4187-0322-5631 name=merchant><INPUT type=image src="http://www.mondellotwister.com/buybutton.gif" value="Add to Shopping Cart" name=additem><INPUT type=hidden value=2811 name=sku><INPUT type=hidden value=$399 name=price><INPUT type=hidden value="Edelbrock Olds Victor Manifold" name=description><INPUT type=hidden value=25 name=weight><INPUT type=hidden value=no name=ship_free><INPUT type=hidden value=no name=jac_minimumquantity><INPUT type=hidden value=yes name=taxable><INPUT type=hidden value=no name=jac_no_shopping_cart><INPUT type=hidden value=yes name=jac_disallowfractionalquantity> <TABLE name="OptionTable"><TBODY><TR><TR><TD><INPUT type=radio value=0;Standard;1 name=jac_prodoptions0 rname="manifold">Standard </TD><TD>$399.00</TD></TR><TR><TD><INPUT type=radio value=+300;Ported;2 name=jac_prodoptions0 rname="manifold">Ported </TD><TD>$699.00</TD></TR><TR><TD><INPUT type=radio value="+149;Hood Mach;3" name=jac_prodoptions0 rname="manifold">Hood Mach </TD><TD>$548.00</TD></TR><TR><TD><INPUT type=radio value=+449;Ported/Mach;4 name=jac_prodoptions0 rname="manifold">Ported/ <TD>$828.00</TD></TR><TR><TD> Hood Mach</TD></TR></TBODY></TABLE></FORM>
    Oct 2003
    HICKORY, NC
    Just take the part numbers, shop around with
    Doug Herbert Performance http://www.dougherbert.com/
    1-877-497-2787
    Summit 1-800-230-3030
    Jegs 1-800-345-4545
    Mar 2002
    Skow-vegas,Maine
    Al,
    Copy'n and past'n is nice but... I really think he was looking for some input from someone who actually had used a performance intake on a 455 and what by comparison would they know would work best for his application. As far as torque goes there will be an excess of that, it is a 455 Olds engine, the only thing in question will be where it comes in and when it peaks.
    81 Sanger Alleycat
    This is really interesting. You guys are making all kinds of suggestions......based on what? Your experience with a car engine....somebody else's experience that you heard about. If you were talking about an intake for a car, would you care if the car had a factory, stock exhaust system? Would that in any way influence your recommendation? Do you think a car will make the same power no matter what exhaust system is used?
    You guys gotta be way smarter than that.
    The exhaust system on a boat has more influence on performance than the exhaust system on a car. Your experience with car engines is helpful when working with a Marine engine, however you will NOT get the same result with the Marine engine that you got with a car engine.
    For example, last Fall I replaced my Edelbrock Performer intake with a Victor. Good move, right. WRONG!! We made cam changes, valve timing changes, ignition timing changes, carb jet changes, it was on the Dyno for 2 weeks. My friend has a Dyno and we were determined to get 500 hp. We got 470 hp. The reason? We did it all with the complete boat exhaust system on the motor.
    Oh yeah, the (port matched) Victor intake LOST 8 hp. We ended up with the Performer that we started with. We did pick up about 40 hp with a cam change.
    I'm sure that more power can be gained/lost with Marine exhaust systems than is possible with any single carb intake change on a boat.
    I'm still waiting for somebody to ask about the exhaust system on this motor.
    Mar 2002
    Skow-vegas,Maine
    If any of that post was directed towards me I think you need to reread my first post, I said consider... I did not say, you HAVE to use this intake. I dont have experience with a 455 in a marine application and I did not state that I did. I know all to well what the exhaust can do for a marine engine, for that matter a bigger carb on a stock intake will yeild quite impressive results versed against some aftermarket intakes on certain marine applications, this I know and I have experienced it myself, yet again not with a 455 Olds. The reason I -suggested- the intake that I did was because it seemed to make a very impressive amount of useable torque and I felt that it might make a good intake on a marine engine.
    81 Sanger Alleycat
  12. #12
    The post is NOT directed at anybody. My intent is to get you ALL to think BEFORE you post.
    Unless the person asking for help declares his degree of expertise on the subject, you should consider that he has none. If your suggestions are conditional, then you should state the conditions that will influence the situation.
    I have NO interest in taking shots at anyone.
    I think that when you suggest someone make a change on the basis of your experience with a car engine, you should make it clear that the same thing might not work for a Marine application. You might even say why....if you know.
    Just trying to avoid misleading folks.
  13. #13
    Mar 2002
    Skow-vegas,Maine
    One more time, I did not mislead anyone and I take it as a shot as you stating so. I said 'I would consider it'. I choose my wording carefully as to not mislead anyone.
    It seems your the one with all the experience...
    81 Sanger Alleycat
  14. #14
    Oct 2003
    HICKORY, NC
    I'm speeking to the person who ask for advice.
    RPM range of your engine has a great deal to do with your selection.
    You should prefer a non-EGR intake.
    That is why I posted the Edelbrock on first.
    Now, yes there are several factors in your intake selection.
    But being a Olds engine, and a monster torque engine, you will notice most all the intakes have same runners. Mostly changing the intake will save weight, reduce heat. A carb spacer 1' or greater will be a great benifit.
    I do not see you below 2000 rpm or above 6000 rpm.
    Al
  15. #15
    Oct 2003
    HICKORY, NC
    Quote Originally Posted by northeastcat
    Al,
    I think you should check to see if that person has or has not used, built, or be around Olds engines.
    But your a great automotive Machinest! So that makes you a performance expert.
    What do I know???
