Results 1 to 1 of 1
    May 2001
    New Hill, NC
    Exclamation New low cost ECU alternative!
    The Brucato Advanced Control Unit (ACU) is designed to be a replacement for your stock ECU on select Mercury outboards.
    At only $1025, the ACU costs hundreds less than a new Mercury ECU.
    The ACU will be programmed with a fuel curve for your engine and includes a mounting bracket for direct replacement. Nothing else to buy!
    Curves and mounting brackets are available for these applications and many more:
    150, 175, 200 HP EFI; 150, 200, 225 ProMax; 220 Laser, 2.5 Drag, 2.4 EFI,
    F1 Motor, 260 EFI We can supply custom fuel curves and rev limits.
    You can read more about the ACU at http://brucatosvs.com/acu.html
    or you can call me @ 919-718-0249
ID:	111336   Click image for larger version.
    Tony Brucato
    (919) 718-0249
