Results 1 to 6 of 6
Thread: fuel problems
    Angry fuel problems
    hello
    i have 1993 2.5 efi 265 hp on a vegas xt , i took it out yesterday, went about 10 miles up river went to leave 2 hrs later , motor would rev up then try to shut down motor would only idle , i idled it for about a hour then i took a pair of pliers and pinchedof the return line . after that it ran perfect all the way to the landing. what is going on. HELP
    Apr 2006
    dublin va
    sounds like bad regulator is it efi ?
    yes it is
    Jul 2002
    Calais, ME
    The regulator has my vote too. If you had to restrict the flow, that is what the regulator does is "regulate" the flow.
    ------------'82 Vector - Mercury 2.4 Bridgeport "MOD"
    "Life is short - Get there fast...MERCURY"
    Sep 2002
    Unless it's another EFI problem of some kind, perhaps a faulty vaccuum TPI causing it to only be able to idle, but stall when you give it throttle. A bad TPI or MAP sensor could do that. Pinching the return line would raise the fuel pressure to the fuel pump's maximum capability, probably around 60 psi. This would richen the overall mixture any maybe allow it to run. Just a crazy idea. A bad regulator is more likely...
    Apr 2006
    dublin va
    get a fuel pressure gauge and check your pressure per mercury manuel. this will tell you for sure if its your regulator.
