Results 1 to 7 of 7
Thread: reed question
05-14-2006, 01:44 PM #15000 RPM
- Apr 2006
- dublin va
- 409
reed question
Got my motor apart right now and thought it had steel reeds inside. When i pulled the reed plate though i found a black plastic type of reed instead. Are these boyseen reeds? How can i tell who made them? Can send a pic of the reed to your email if that will help. My pic are above the limit for posting on this site...
05-14-2006, 02:12 PM #2
Boyesen reeds
If they are black, dual-stage plastic reeds, they are most likely made by Boyesen.
Shrink the picture and post it here. I am sure someone can tell.Markus' Performance Boating Links:
05-14-2006, 02:18 PM #35000 RPM
- Apr 2006
- dublin va
- 409
reed pic
05-14-2006, 02:21 PM #45000 RPM
- Apr 2006
- dublin va
- 409
sorry now i have to figure out how to make it smaller
05-14-2006, 07:15 PM #5Screaming And Flying!
- Dec 2001
- 9,502
- 269
- 191
- 1975
Reeds
If you got into your motor too the reeds you should be able to rebuild it your self with the help of S+F. Sounds like boyesens.
05-14-2006, 07:47 PM #65000 RPM
- Apr 2006
- dublin va
- 409
worked out a trade on some parts with another member. Rebuild looks simple other then getting them needle bearings in around where the piston and rod connect.
05-14-2006, 08:33 PM #7
Rick,
check your email.James Perry
