Results 1 to 4 of 4
Thread: Electric fuel pump
05-13-2006, 01:41 PM #1
Electric fuel pump
What is the best way to connect an electric fuel pump? The Merc 200 I bought used, has an electric pump connected in line before the mech pump. (That is the same way the inboards I've owned were done) but I've seen a few outboards that bypass the mech pump completely. If this is the way to go, do I need to do anything to the mech pump or just bypass it?
Thanks for your help!
Hobe
05-13-2006, 02:45 PM #2
Hobe,
You can remove the pump from the motor, you will need to plug off the pulse hole behind where it was mounted and put a pipe plug in the block where the 90* fitting is on the crankcase that the other pulse hose was connected to.
-MichaelMichael Chapman
Calhoun Marine
803-897-3806
1166 Midway Rd
Elloree S.Carolina 29047
quartermaster22@gmail.com
http://www.facebook.com/album.php?ai...112543?sk=wall
05-14-2006, 01:05 PM #3
you shouldn't need to run an electric pump for that motor. Mercury fuel pumps work fine for many applications. I would rebuild the stock pump and forget the electric pump altogether.
05-14-2006, 06:58 PM #45000 RPM
- Feb 2006
- 423
pumps
I have had no problems with stock 200's with carbs and mech pump. they are simple and effective. also maybe a little safer. but if you do decide to run a electric, do lile m.chapman says and dont forget to use a pressure regulator set at 3 to 4 psi. good luck, john
