Results 1 to 9 of 9
    Southeast Texas
    Fuel Pump Question?
    will the same pump that came stock on a '96 2.5 efi with a 36# digital brain feed enough fuel to supply an A-63 box with a 56# regulator....thanks
    RIP Todd Carter, Ronnie, Galen...
    You'll never be forgotten
    ILLINOIS
    Cool Yes..............
    it will work fine. The older smaller Bosche won't do it but the bigger ones 056 etc. will go 90psi and still do the volume needed for a stock or somewhat modded 260. At 56psi on a drag , they will still work too but the Weldon is a better pump for high pressure AND high volume.
    May 2001
    Los Angeles Ca
    Southeast Texas
    fuel pump
    is the weldon a factory pump from merc. or an aftermarket one?..what did it come on?....thanks
    Alabama
    fuel pump
    dennymac;
    the later bosch pump will have the # 0 580 254 957. you can probaly get this crossed out at a parts store and buy if for half of what merc wants.
    May 2001
    Los Angeles Ca
    Nov 2001
    Darlington SC
    fuel pumpsdoe
    does anybody know what one of these big bosch pumps cost.
    if ya need more than one for a260 if ya are spinning it pretty hard
    or is a single pump good enough?
    May 2001
    Los Angeles Ca
    Extreme Southeast Georgia
    Fuel Pumps
    Question:
    I have two pumps, both new in the box. One is a Bosch in the Bosch box with P/N 61957 0 580 254 957 - 390. The Bosch has a nipple for hose and clamp on the suction side and a -6 AN fitting on the discharge. The other is from Kinsler Fuel Injection, no numbers on it. Looks similiar to the Bosch. It is fatter than the aforementioned pump and is set-up with -AN fittings on both ends. A -8 on the suction side and a -6 on the discharge. Anyone know what the differences are? Thanks
    Wayne
