Results 1 to 3 of 3
03-24-2006, 01:26 PM #1
Mercury Impeller Differences between Lower Units
What is the difference in water pump impellers and housings in 2.4 V6 application such as a standard lower unit VS 4 hole CLE in 90-93 years.
When replacing an impeller for a switched out lower unit what do you ask for?
Are all 2.4 lower unit housings using the same impeller?
Thanks for any information!
03-24-2006, 02:58 PM #2Team Member
- Mar 2005
- Mid-Michigan
- 1,244
The impellers are the same, Merc. #47-89984,this is used in the 2.5 gearcases also. The upper housing's are the same, but there are 2 diff. lower housing's. Get the lower housing for what the gear case is.
03-24-2006, 04:06 PM #3
Thank You for your help.............
